I/Os of the top-level block are called port, I/Os of the subblocks are called pin. So get_ports
and get_pins
commands must be used accordingly.
If the main clock is an input of the top-level block, get_ports
is the appropriate command. For example:
create_clock -name CLK [get_ports clock_main] ...
Since clock_1
and clock_2
are the inputs of the subblocks, get_pins
must be used in this case.
create_clock -name CLK1 [get_pins Module_1/clock_1] ...
create_clock -name CLK2 [get_pins Module_2/clock_2] ...
The signals other than the I/Os are called net. The nets may be collected and constrained by using get_nets
command, however most of the synthesis tools optimize out them or change the names. It is better to avoid using get_nets
if not mandatory. Otherwise most of the synthesis tools require dont_touch
attribute or something similar to keep the net.
Normally I don't use get_registers
command, because it's not supported by Synopsys Design Compiler, I use get_cells
instead. On the contrary, Quartus II supports get_registers
according to Altera's SDC manual.
It can be also used to constrain the clock. The manual has the following example:
create_generated_clock -divide_by 2 -source [get_ports clk] -name clkdiv \
[get_registers clkdiv]
Alternatively you may use get_pins
command. It's up to you.
[get_pins clkdiv/Q]
If you have such a clock divider in your design, it's better to constrain it on the register or Q pin than the clock input of a subblock (e.g. Module_1
). Otherwise the synthesis tool doesn't know whether the path carries a clock signal between the register and the clock_1
pin. The delay of the path is not included in the timing analysis etc.
Synthesis tools commonly add suffixes to the signal and cell names. Each tool has its own naming rules. For example, my tool adds _reg
suffix to the flopped signals.
