-1
I'm looking for advice on finding an alternative diode for a negative feedback amplifier I'm repairing.
I hope there's a database I can search for specs and see some options.
M8513A-R Diodes Forward Reference Diode
If Max (A)
I(FSM) Max.(A) Pk.Fwd.Sur.Cur.
V(FM) Max.(V) Forward Voltage 620m
@I(FM) (A) (Test Condition) 3.0m
I(RM) Max.(A) Reverse Current 10u
@V(R) (V)(Test Condition) 5.0
Semiconductor Material Silicon
Package Style DO-35
Description: Junction Varistor for Temp/Bias Comp;Vf-2.1V/C
closed as unclear what you're asking by Leon Heller, Voltage Spike, R Drast, winny, Lior Bilia Nov 13 '17 at 20:44
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ so, ok, you got the specs of the current diode down – but that doesn't tell us which of those are important to your application! so, you'll have to share the schematic that this device has, and what the diode does in particular. \$\endgroup\$ – Marcus Müller Nov 12 '17 at 11:52
    \$\begingroup\$ (1) "... an alterntative diode for a negative feedback amplifier ...". What's wrong with the diode you've got? (2) Most of the online suppliers have parameterised component selection filters. (3) If you want someone to give you a part number then see Don't ask. \$\endgroup\$ – Transistor Nov 12 '17 at 12:00
  • \$\begingroup\$ Here's the schematic elektrotanya.com/toshiba_sc-335_stereo_amplifier_sch.pdf/… \$\endgroup\$ – Nathan Friend Nov 12 '17 at 14:50
  • \$\begingroup\$ The 3 original diodes on the right channel have failed. The part appears to be discontinued. \$\endgroup\$ – Nathan Friend Nov 12 '17 at 16:48
You could use the parametric search of any major distributors. Among them I like digikey's one.
Enter a keyword in the home page, select a category in the search result page and you'll enter the parametric search page. For example, searching for "diode" and then selecting "diodes - rectifiers - single" brings you here.
Have fun with that page!
  • \$\begingroup\$ Thanks Lorenzo, the digikey site is just what I had in mind. \$\endgroup\$ – Nathan Friend Nov 12 '17 at 16:49
