Minimum number of complementary CMOS transistors pair will be required to implement function,\$F=ABC+\overline{(A+B+C)}\$ are?
\$(A)6\$
\$(B)7\$
\$(C)8\$
\$(D)9\$
I tried like this but I am getting 7 CMOS pair but answer key says its 9 CMOS pair.whats the mistake I am doing? enter image description here
You did it wrong by connecting the output of the first stage to the output of the second stage. The correct way would be :enter image description here
TOTAL = 4 + 3 + 2 = 9 CMOS pairs
  • \$\begingroup\$ sir i have still one doubt please clarify what will be the output when i cascade it like that in my answer?I am just confused why thats wrong actually. \$\endgroup\$ – Rohit Nov 16 '17 at 13:14
  • \$\begingroup\$ Unpredictable/undefined if both outputs are driving different logic level at the same time. We don't do it in a circuit. \$\endgroup\$ – Mitu Raj Nov 16 '17 at 13:43
    \$\begingroup\$ You can do like that ONLY for open collector/drain gates, where only one of the gates drives the output at a time, and other gates goes to high impedance state. Check this Wikipedia article - "Wired logic connection " \$\endgroup\$ – Mitu Raj Nov 16 '17 at 13:53
The problem is not in the second stage, it is in the 1st stage. A+B+C shouldn't be connected in series in nmos to get required answer, it is a blunder. But the not of A B C should be connected in series.So you require 3 not gates to prepare A B C not. So Then the 2nd stage is not even required. Thank you.
