I am currently working on a simple AC Mains Indicator and would love to have a blown fuse indicator on my primary circuit.
After some searching on google, I came accross this circuit:
http://electronicsforu.com/electronics-projects/blown-fuse-indicator
What I'd like to know is what kinds of LED (the red and green ones) should I use here? Can I use the typical 5mm LED lamps?
closed as unclear what you're asking by clabacchio Nov 16 '17 at 15:32
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
It has a 100K Ohm resistor, with 220V and V = I * R <=> I = V / R = 220 / 100,000 = 0.002 A = 2 mA it will barely light up but still ok. So yes, a typical 3 mm or 5 mm can be used. For a lighter diode you can use a less big resistor (most LEDs can have 20 mA or more).
I didn't take the forward voltage into account, but is negligible.
About the LED itself, it shows a bicolor LED, so you can use a typical 3mm or 5mm bicolored LED.
