I want to design a UART receiver/transmitter and by now I already developed the receiver vhdl file but when declare and instantiate the the receiver component on my Mainboard Design I get very much syntax errors in both files, mainboard and uart-receiver.
The following is the mainboard design. I use generics. Could the problem be here? I already tried different approaches like setting the generics with ":" or with "=>" in the instantiation but nothing worked. It is a vhdl design for an altera FPGA (Cyclone V), I'm using Quartus II Lite. I got the design from an Internet Site (https://www.nandland.com/vhdl/modules/module-uart-serial-port-rs232.html)
LIBRARY IEEE;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY mainboard is
PORT( CLOCK_50_B5B : IN STD_LOGIC;
LEDG : OUT STD_LOGIC_VECTOR(7 downto 0);
LEDR : OUT STD_LOGIC_VECTOR(7 downto 0);
KEY : IN STD_LOGIC_VECTOR(4 downto 0);
CPU_RESET_n : in STD_LOGIC;
GPIO : INOUT STD_LOGIC_VECTOR(36 downto 0)
END ENTITY;
ARCHITECTURE behavior of mainboard is
SIGNAL LED_7 : STD_LOGIC;
SIGNAL LED_6 : STD_LOGIC;
SIGNAL CLK100 : STD_LOGIC;
SIGNAL locked : STD_LOGIC;
SIGNAL SF_D_signal : STD_LOGIC_VECTOR(3 downto 0);
SIGNAL Reset : STD_LOGIC;
SIGNAL RX_byte_sig : STD_LOGIC_VECTOR(7 downto 0);
component uart_rx
generic (g_CLKS_PER_BIT : integer);
port (
i_clk : in std_logic;
i_rx_serial : in std_logic;
o_rx_dv : out std_logic;
o_rx_byte : out std_logic_vector(7 downto 0)
end component;
component Test1_Led
port ( clk_in : in STD_LOGIC;
led_out : out STD_LOGIC);
end component;
component test
port ( refclk : in std_logic;
rst : in std_logic;
outclk_0 : out std_logic; -- outclk0.clk
locked : out std_logic);
end component;
component lcd_control
port ( clk : in STD_LOGIC;
reset : in STD_LOGIC;
init : in STD_LOGIC;
init_ok : out STD_LOGIC;
row_select : in STD_LOGIC;
Data_in : in STD_LOGIC_VECTOR(19 downto 0);
SF_D : out STD_LOGIC_VECTOR(11 downto 8);
LCD_E : out STD_LOGIC;
LCD_RS : out STD_LOGIC;
LCD_RW : out STD_LOGIC;
SF_CE0 : out STD_LOGIC);
end component;
constant c_CLKS_PER_BIT : integer := 54;
BEGIN
lcd1 : lcd_control
port map ( clk => CLOCK_50_B5B,
reset => Reset,
init => '1',
init_ok => LEDG(0),
row_select => '0',
LCD_RS => GPIO(35),
LCD_RW => GPIO(33),
LCD_E => GPIO(31),
SF_D(11 downto 8) => SF_D_signal(3 downto 0),
SF_CE0 => GPIO(0),
Data_in => "00010010001101000000");
led1 : Test1_Led
port map ( clk_in => CLOCK_50_B5B,
led_out => LED_7);
led2 : Test1_Led
port map ( clk_in => CLK100,
led_out => LED_6);
test_inst : test
port map ( refclk => CLOCK_50_B5B,
rst => not KEY(0),
outclk_0 => CLK100,
locked => locked);
uart_rx_inst : UART_RX
generic map ( g_CLKS_PER_BIT => 54)
port map (i_Clk => CLOCK_50_B5B,
i_RX_Serial => GPIO(1),
o_RX_DV => LEDG(3),
o_RX_Byte => RX_byte_sig);
Reset <= not CPU_RESET_n;
LEDG(7) <= LED_7;
LEDG(6) <= LED_6;
LEDG(5) <= CPU_RESET_n;
LEDG(4) <= Reset;
LEDR(7) <= GPIO(1);
GPIO(19) <= SF_D_signal(0);
GPIO(21) <= SF_D_signal(1);
GPIO(23) <= SF_D_signal(2);
GPIO(25) <= SF_D_signal(3);
LEDR(3 downto 0) <= SF_D_signal(3 downto 0);
END ARCHITECTURE;
The Uart Design File (entity) is coded like this:
library ieee;
use ieee.std_logic_1164.ALL;
use ieee.numeric_std.all;
entity UART_RX is
generic (g_CLKS_PER_BIT : integer := 54);
port ( i_Clk : in std_logic;
i_RX_Serial : in std_logic;
o_RX_DV : out std_logic;
o_RX_Byte : out std_logic_vector(7 downto 0));
end UART_RX;
I got the following errors:
Error (10500): VHDL syntax error at mainboard.vhd(96) near text "Â"; expecting >";", or "port", or "generic"
Error (10500): VHDL syntax error at mainboard.vhd(97) near text "port"; >expecting "<="
Error (10500): VHDL syntax error at mainboard.vhd(98) near text "Â"; expecting >"!", or "=>"
Error (10500): VHDL syntax error at mainboard.vhd(99) near text "Â"; expecting >"!", or "=>"
Error (10437): VHDL Association List error at mainboard.vhd(98): positional >associations must be listed before named associations
Error (10500): VHDL syntax error at mainboard.vhd(100) near text ";"; >expecting "<="
And in uart file:
Error (10500): VHDL syntax error at UART_RX.vhd(5) near text "Â"; expecting >"entity", or "architecture", or "use", or "library", or "package", or >"configuration"
Error (10500): VHDL syntax error at UART_RX.vhd(7) near text "Â"; expecting >"end", or "begin", or a declaration statement Error (10523): Ignored construct UART_RX at UART_RX.vhd(6) due to previous >errors
Error (10500): VHDL syntax error at UART_RX.vhd(15) near text "Â"; expecting >"entity", or "architecture", or "use", or "library", or "package", or >"configuration"
Error (10500): VHDL syntax error at UART_RX.vhd(18) near text "Â"; expecting >"begin", or a declaration statement
Error (10500): VHDL syntax error at UART_RX.vhd(20) near text "Â"; expecting >")", or "," Error (10500): VHDL syntax error at UART_RX.vhd(21) near text "Â"; expecting >"begin", or a declaration statement
Can you help me finding the mistake?
