I have the following code for testing an LED:
configGlobal.h
#define F_CPU 1000000UL
#define setBit(sfr, bit)     (_SFR_BYTE(sfr) |= (1 << bit))
#define clearBit(sfr, bit)   (_SFR_BYTE(sfr) &= ~(1 << bit))
#define toggleBit(sfr, bit)  (_SFR_BYTE(sfr) ^= (1 << bit))
main.c
#include "configGlobal.h"
#include <avr/io.h>
#include <util/delay.h>
#define LED PB0
#define LED_DDR DDRB
#define LED_PORT PORTB
int main(void) {
  // -------- Inits --------- //
  DDRB |= 0b00000001;            /* Data Direction Register B:
                                   writing a one to the bit
                                   enables output. */
  // ------ Event loop ------ //
  while (1) {
    PORTB = 0b00000001;          /* Turn on first LED bit/pin in PORTB */
    _delay_ms(1000);                                           /* wait */
    PORTB = 0b00000000;          /* Turn off all B pins, including LED */
  }                                                  /* End event loop */
  return 0;                            /* This line is never reached */
Using avrdude, the code gets loaded on the chip with the following verbose output. The LED does not light up as expected, but shortly flickers when the code gets loaded on the chip.
AVR Development Stack
Get input main.c file...
Compile code and return elf file...
Convert elf file to hex...
Uploading data to microcontroller...
avrdude: Version 6.3, compiled on Sep 18 2017 at 20:31:51
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/usr/local/Cellar/avrdude/6.3/etc/avrdude.conf"
         User configuration file is "/Users/sebastianscharf/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbtiny
         Overriding Baud Rate          : 9600
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 020:008
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
CMD: [ac 53 00 00] [00 00 53 00]
avrdude: AVR device initialized and ready to accept instructions
Reading |                                                    | 0% 0.00sCMD: [30 00 00 00] [00 30 00 1e]
CMD: [30 00 01 00] [00 30 00 95]
Reading | #################                                  | 33% 0.00sCMD: [30 00 02 00] [00 30 00 0f]
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
CMD: [50 00 00 00] [00 50 00 62]
avrdude: safemode read 1, lfuse value: 62
avrdude: safemode read 2, lfuse value: 62
avrdude: safemode read 3, lfuse value: 62
avrdude: safemode: lfuse reads as 62
CMD: [58 08 00 00] [00 58 08 d9]
avrdude: safemode read 1, hfuse value: d9
avrdude: safemode read 2, hfuse value: d9
avrdude: safemode read 3, hfuse value: d9
avrdude: safemode: hfuse reads as D9
CMD: [50 08 00 00] [00 50 08 ff]
avrdude: safemode read 1, efuse value: ff
avrdude: safemode read 2, efuse value: ff
avrdude: safemode read 3, efuse value: ff
avrdude: safemode: efuse reads as FF
avrdude: safemode: Fuses OK (E:FF, H:D9, L:62)
avrdude done.  Thank you.
  • \$\begingroup\$ Looks like an analog current problem may exist too. What controls the current limit? and voltage glitches? \$\endgroup\$ Nov 18, 2017 at 18:55
  • \$\begingroup\$ Hi @TonyStewart.EEsince'75. What do you mean by that? \$\endgroup\$
    – sesc360
    Nov 18, 2017 at 18:56
  • \$\begingroup\$ Are you sure you can drive the load ? \$\endgroup\$ Nov 18, 2017 at 18:56
  • \$\begingroup\$ My USBTiny Bootloader is connected via USB to my mac and provides the current through USB. It should all work, I would say \$\endgroup\$
    – sesc360
    Nov 18, 2017 at 18:57
    \$\begingroup\$ Being sure means you have computed the current limit and verified that the switch works. Since this is unknown to us, I trust you know what it is. \$\endgroup\$ Nov 18, 2017 at 19:59
If your LED is flickering when the code is getting loaded, it's likely that you put it on the wrong pin. You are toggling PB0 - pin number 14. The ISP uses the SPI pins (PB1 - PB3) which are chip pin numbers 17 - 19 (for the DIP package).
ATmega328 Pins
You have some nice defines, but aren't using them. Although, I'd get rid of those junk macros in configGlobal.h. Try this:
#include <avr/io.h>
#define LED _BV(PB0)     // = (1 << PB0)
int main (void) {
  LED_DDR = LED;   // Set the LED pin as an output
  for(;;) {
    LED_PORT ^= LED;   // Toggles just the LED pin
    _delay_ms(1000);
I verified this code on a virgin ATmega328p chip compiled with AVR-GCC and programmed using AVRDUDE. MCU is powered from 5V with an LED connected to Pin PB0 (chip pin 14) with a 1k series resistor.
