I'm considering retrofitting skylight motors but would like to know if I can use standard home switches to control it. I have not found examples of up, down and open switches (is this 3 pole, normally open?). I imagine this should be similar for blinds or any motor that steps in two directions (but not just fully open or fully closed like a garage door).
The skylight manual contains this diagram, first below.
The second I simplified because I don't understand the need for a double-pole, double throw where the Neutral disconnects when untouched. Any ideas why they would want that?
Finally the third diagram shows my idea to use two momentary switches which I believe should work. However would anyone be able to speculate if the motor is likely to have protection against both open and closed being pressed simultaneously? Am I overlooking anything else?
Update The winning solution is: https://electronics.stackexchange.com/a/340685/169328
The local supplier of one brand, Topp, that operates at mains voltage supplied the following diagram with matches second circuit diagram 2(b).
This uses two common momentary switches. Note how 2 feeds into C of the second switch.
