I trying to create a circuit with only one 555 to send HIGH on output(3) for very short time, like 200ms, then set LOW for something like 20~30 seconds.
Then I'm just need turn on circuit, then: a) fast HIGH (~200ms) b) long LOW (~20-30s)
I already able to make a "default" 555 circuit with stable HIGH/LOW in same timing (1000ms/1000ms), but I'm getting trouble to make this with different HIGH and LOW timmings.
Thanks.
General approach is to separate the discharge resistor into two using diodes.
The capacitor C2 charges through R1 + R3 and discharges through R2, ignoring diode drops and discharge transistor collector voltage when on.
Approximately, on time is proportional to R1 + R3 and off time is proportional to R2, so you can make the ratio suit your application.
