I have that power amplifier schematic.
  1. Why it's written that it's class A? I think that only voltage gain stage is class A and output is class AB or it's not so?
  2. Why the collector of Q8 is at ground? What that ground actually do and does the Q8-Q9 stage is a darlington stage or not?
  3. How much voltage must be between C-E of Q10 rubber diode to avoid output distortion?
1) Class A simply means that even under maximum signal conditions, the output transistors (here Q12 and Q14) should always have some collector current flowing through them.
So is it simply a matter of biasing (choosing the operating point) of the output stage such that this (Ic > 0) is always true. You can do that by making the quiescent current large and/or limiting the maximum power.
So I could also for example say that this same design is a 40 W class AB Audio amplifier (I'm for argument's sake assuming it can do 40 W in class AB) which works in class A up to 20 W.
2) The collector of Q8 just needs to be connected to a supply rail. If it was connected to the +22 V rail then Q8 would need to dissipate a lot more power. Since the emitter of Q8 is at about -21.3 V (-22 V + 0.7 V) there is plenty of "headroom" for Q8 to have 0 V (ground) at the collector. So there's nothing special about the connection to ground, it is used as a supply rail.
Yes Q8 and Q9 indeed form a darlington pair. This limits the load on the current output formed by Q1 and Q3. If Q8 was removed the gain in the amplifier would drop significantly.
3) The "zener" made by Q10 sets the quiescent current in the output stage. So as mentioned under 1) you can then choose the range in which the amplifier works in class A. In creasing the voltage means a higher quiescent current and also a higher power dissipation!
The overall distortion of this amplifier is not only determined by how much voltage you set across Q10. This amplifier also has feedback, not the 510 ohm and 10 kohm resistors connected to the base of Q2. This feedback network (10 kohm + 510 ohm + 220 uF capacitor, ignore the diodes, they are for protection only) sets the gain of the amplifier and this also reduces distortion.
So the overall distortion is determined by both the feedback and how you set the quiescent current of the output stage.
  • \$\begingroup\$ The D1, D2 protection normally does nothing as there should be no DC voltage (0 V DC) across the 220 uF cap. If there was 1 V DC across that cap then that would mean there would have to be a DC voltage at the output of the amplifier as well. Would you like some DC across your speakers? No, neither would I. \$\endgroup\$ – Bimpelrekkie Nov 20 '17 at 15:54
  • \$\begingroup\$ It can happen that after power on there is some DC across the 220 uF cap and that is OK as long as it is positive (VDC > 0). Since the 220 uF cap is polarized it cannot handle a large negative voltage. That's where D1 and D2 come in, they then conduct and limit it to -1.4 V which is OK \$\endgroup\$ – Bimpelrekkie Nov 20 '17 at 15:54
  • \$\begingroup\$ You choose what you want as the quiescent current in the output stage and set VR1 accordingly, you measure the voltage across the 0.1 ohm resistors and calate the current. 100 mV across 0.1 ohm is 1 A. There is no right/wrong it is just a trade off you can make between power dissipation and class A operation. \$\endgroup\$ – Bimpelrekkie Nov 20 '17 at 15:56
  • \$\begingroup\$ May be Q10 CE voltage less than 1.4V? \$\endgroup\$ – MaxMil Nov 20 '17 at 16:01
  • \$\begingroup\$ Is it valid to suppose that if for example I choose 100 mv across 0.1 ohm I will get the class A operation before the ouput collector current achieves 1A and after that it will be the class AB operation? \$\endgroup\$ – MaxMil Nov 20 '17 at 16:06
