I recently got a box of vintage stuffs. I came across this stuff. Its powered by a 9V battery. Does anyone has any idea what this is?
IMG 1
IMG 2
  • \$\begingroup\$ Hm. "m/s" - minutes/seconds? A stopwatch? \$\endgroup\$
    – Eugene Sh.
    Nov 20, 2017 at 17:34
  • \$\begingroup\$ meters/s? are the two holes in the bottom optical sensors for measuring the speed of a moving object? \$\endgroup\$
    – bobflux
    Nov 20, 2017 at 17:35
  • \$\begingroup\$ Can you put a battery in and see what it does? Well, there is a little chance it will explode... \$\endgroup\$
    – Eugene Sh.
    Nov 20, 2017 at 17:37
  • \$\begingroup\$ It was a big box with so so many items. I'm yet to sort all the other items like intel 80386 mobs, TI55, TI59 etc etc . I'll try to see if I can find anything that can into those two holes. \$\endgroup\$ Nov 20, 2017 at 17:40
  • \$\begingroup\$ @EugeneSh. Yes I tried putting the battery and it just showed "00.0". That's all. \$\endgroup\$ Nov 20, 2017 at 17:40
That's most likely a display armature for an anemometer. Wilh. Lamprecht, Göttingen produces all kind of weather science equipment.
  • \$\begingroup\$ meters/seconds. Makes sense. \$\endgroup\$
    – Eugene Sh.
    Nov 20, 2017 at 17:47
  • \$\begingroup\$ You guys are right. It probably might be, but this particular instrument is nowhere to be seen on the google searches. \$\endgroup\$ Nov 20, 2017 at 19:56
  • \$\begingroup\$ @Janka You were right the top part is missing. I connected a motor to it with a fan and placed it in front of continuous air flow to generate current and that gave me reading on the meter. Though I'm not sure if it works by the same principle. When you suggested that its an anemometer it gave me this idea as most modern anemometers have that electric fan. \$\endgroup\$ Nov 24, 2017 at 20:02
