I would like for debugging/trace purposes to print texts (preferably via printf but just text is also fine) from an STM32F103C8T6 to a (PC) terminal application.
I noticed that all examples use a Nucleo or Discovery board but I don't have those. I'm using ST Link/V2 and System Workbench (Eclipse).
Does anybody know how to do this or if it is even possible? (I guess so with some USB/RS232 converter maybe).
    \$\begingroup\$ You can print the string on any UART lines and use a UART to USB converter to see it on PC terminal. Because a Nucleo/Discovery has a onboard UART/USB converter which does exactly the same thing. \$\endgroup\$ – ammar.cma Nov 22 '17 at 10:25
    \$\begingroup\$ Check this tool: st.com/en/development-tools/stm-studio-stm32.html A bit better than sending strings. \$\endgroup\$ – Bence Kaulics Nov 22 '17 at 11:30
  • \$\begingroup\$ @BenceKaulics If it works together with Eclipse than it would be very useful. \$\endgroup\$ – Michel Keijzers Nov 22 '17 at 11:41
    \$\begingroup\$ It is not a plugin but a completely independent tool. \$\endgroup\$ – Bence Kaulics Nov 22 '17 at 12:17
  • \$\begingroup\$ @BenceKaulics I know ... but I cannot e.g. use ST Link Utility together (simulatenously) with Eclipse, probably with that tool I have the same problem. \$\endgroup\$ – Michel Keijzers Nov 22 '17 at 12:18
All the STM32F0 that I can think of come with UART hardware – meaning that you just need to write your string to some address, and trigger the transfer.
The knowledge of how to do that can be taken from the Reference Manual of that family (ST Document number RM0008), or just straight from the UART driver within the STM Cube software package.
Electrically, you'll really get a TTL UART – any TTL serial-to-USB converter will do. The Nucleo boards just contain a second microcontroller that plays a USB-to-STLink and USB-to-TTL-UART bridge.
For "easy" debugging, the UART is certainly the least error-prone communications interface in the chip. If you're tempted to directly communicate with the PC: Your MCU comes with a USB2 transceiver. You can, adding a few resistors, directly connect that to your PC, and let it look like a serial adapter itself, just giving you your messages or data! That is, given you have a firmware that handles the USB stack. ST offers a library to do that, and that comes with examples. Be warned though that USB is way more complicated than UART, and if you just want to occasionally print short strings, UART certainly is sufficient. The USB interface allows you to send USB data packets through USB2 Full Speed (that's the 12Mb/s standard) – that can be hell of an advantage if you need e.g. to build something that samples a signal rapidly (that's why I used USB on an ARM the first time) in the long term.
  • \$\begingroup\$ Thanks for the answer ... I just need some data (I doubt I need 12 MB/s, at least not for now)... I will check further into the TTL serial to USB converter ... will my PC automatically detect it as a com port or should I install a driver to have it visible in a terminal application? \$\endgroup\$ – Michel Keijzers Nov 22 '17 at 10:31
    \$\begingroup\$ Windows generally comes with drivers installed because this has been around for a while. Use HyperTerminal or PuTTY to open the COM port on the baud rate you set in firmware and you should be able to see the ASCII characters. \$\endgroup\$ – ammar.cma Nov 22 '17 at 10:33
  • \$\begingroup\$ @ammar.cma Thanks ... also I found this learn.sparkfun.com/tutorials/how-to-install-ftdi-drivers/all to install ftdi drivers, so even in case it is not autoamtically I can try that. \$\endgroup\$ – Michel Keijzers Nov 22 '17 at 10:34
    \$\begingroup\$ @MichelKeijzers It depends on the TTL/USB adapter you get and which chip it uses inside. FTDI is common, but cheap knockoffs come from different vendors and thus different drivers. Although, you shouldn't have a problem with drivers. (tons of online tutorials for that) \$\endgroup\$ – ammar.cma Nov 22 '17 at 10:36
  • \$\begingroup\$ @ammar.cma I have a cheap knockoff probably ... but I will check if it works (when I have time)... it's a 'hobby' project getting out of hand a bit :-) ... but a good way to learn about microprocessors. \$\endgroup\$ – Michel Keijzers Nov 22 '17 at 10:49
There is no problem with it. You have few options. The first way is to configure your UART (the process may be very straightforward if you use CubeMX) to send text and then hook-up RX and GND pins of your USB-RS232 to TX and GND pins of your board respectively. Then you can transmit your logs for example with function HAL_Uart_Transmit(). More advanced option is to redirect stdout to that UART. But it will take a lot of effort to configure and run this.
There is much better and easier way to achieve your goal and it is shown in the video. Original ST-Link V2 (and even chinese clones except the cheapest dongles) have SWO pin. You can redirect stdout of your application through this interface by means of ITM Trace technology which is a part of CoreSight debug core of your MCU. First of all you should enable SWO pin in CubeMX utility. Then you should redirect your stdout to ITM macrocells, for that purpose you can use code from this article. It will allow to do a printf-style logging. To see those logs you can use SWO viewer from st-link utility ("Printf via SWD" button). There may be a problem if you use SWO viewer from ST-link utility and debugger from your IDE simultaneously: ST-link driver won't work with two apps simultaneously. That is why I recommend to use more advanced IDE's. You can take a look at Keil uVision: it allows to use ITM and debugger capabilities simultaneously from uVision debugger. They have evaluation licenses, so you can give it a try.
There is a third way to solve your problem and it is called semihosting. I have a very tiny experience with it and I cant recommend using it. A semihosted event halts the MCU and needs support from the debug tools to handle the semihosted operation and without debug tools attached, a semihosted event will permanently halt the MCU.
  • \$\begingroup\$ I will try the first mechanism ... the SWO seems good, but it's not nice to have not simultaneously an IDE open (I need to upload very often). And it's for a hobby project, probably Keil is too expensive to buy just for some hobby. The last sounds interesting too, although I'm afraid it will affect my real program which I want to debug (using interrupts via DMA). \$\endgroup\$ – Michel Keijzers Nov 22 '17 at 11:04
    \$\begingroup\$ @MichelKeijzers keil have free evaluational licenses with 32kb code limit. If your app is less than that, you can give it a try. Believe me: with SWO you can achieve your result much faster, than with any other way. Besides there are still some ways to make it work with System Workbench. \$\endgroup\$ – Vadimchik Nov 22 '17 at 11:15
    \$\begingroup\$ @MichelKeijzers You can use ITM with the IDE still open and connected. In fact that's how I used it the first time I used STM32. I did not know that you could read printfs over debug interface. I was surprised to see printf output when I had neither connected the USB port nor the UART on the MCU to my computer. You can use breakpoints etc. also. Point is it does not interfere with the way you'd normally use your IDE and Debugger. \$\endgroup\$ – Dojo Feb 22 '18 at 16:28
    \$\begingroup\$ @MichelKeijzers I had tried this in AC6 System Workbench. Just got a mailer form ST that True Studio Pro is now free! Got to try it! \$\endgroup\$ – Dojo Feb 22 '18 at 17:28
    \$\begingroup\$ @Dojo Thanks ... I installed it yesterday and seems to work fine, I even could use C++ (with some ugly changes though). \$\endgroup\$ – Michel Keijzers Feb 23 '18 at 10:04
