I bought a generic OLED 128x64 display on ebay and had some success in getting it running with the Adafruit SSD1306 library. I ported the initialization function to C and am driving the LCD using the SPI interface. However, when the splash screen appears, there is a horizontal offset.
I think should be possible to patch this by modifying the display function. However, my question is, is there a cleaner way to do this in the configuration settings for the OLED display. The relevant initialization settings that I am using are given below:
void ssd1306_init(uint8_t vccstate) {
// Init sequence
ssd1306_command(SSD1306_DISPLAYOFF); // 0xAE
ssd1306_command(SSD1306_SETDISPLAYCLOCKDIV); // 0xD5
ssd1306_command(0x80); // the suggested ratio 0x80
ssd1306_command(SSD1306_SETMULTIPLEX); // 0xA8
ssd1306_command(SSD1306_LCDHEIGHT - 1);
ssd1306_command(SSD1306_SETDISPLAYOFFSET); // 0xD3
ssd1306_command(0x0); // just changes the horizontal offset
ssd1306_command(SSD1306_SETSTARTLINE | 0x0); // line #0
ssd1306_command(SSD1306_CHARGEPUMP); // 0x8D
if (vccstate == SSD1306_EXTERNALVCC)
ssd1306_command(0x10);
else
ssd1306_command(0x14);
ssd1306_command(SSD1306_MEMORYMODE); // 0x20
ssd1306_command(0x00); // 0x0 act like ks0108
ssd1306_command(SSD1306_SEGREMAP | 0x1);
ssd1306_command(SSD1306_COMSCANDEC);
if( SSD1306_LCDWIDTH == 128 && SSD1306_LCDHEIGHT == 32) {
ssd1306_command(SSD1306_SETCOMPINS); // 0xDA
ssd1306_command(0x02);
ssd1306_command(SSD1306_SETCONTRAST); // 0x81
ssd1306_command(0x8F);
else if (SSD1306_LCDWIDTH == 128 && SSD1306_LCDHEIGHT == 64) {
ssd1306_command(0x12);
ssd1306_command(0x9F);
else
ssd1306_command(0xCF);
else if (SSD1306_LCDWIDTH == 96 && SSD1306_LCDHEIGHT == 16) {
ssd1306_command(0x2); //ada x12
else
ssd1306_command(0xAF);
ssd1306_command(SSD1306_SETPRECHARGE); // 0xd9
ssd1306_command(0x22);
else
ssd1306_command(0xF1);
ssd1306_command(SSD1306_SETVCOMDETECT); // 0xDB
ssd1306_command(0x40);
ssd1306_command(SSD1306_DISPLAYALLON_RESUME); // 0xA4
ssd1306_command(SSD1306_NORMALDISPLAY); // 0xA6
ssd1306_command(SSD1306_DEACTIVATE_SCROLL);
//Debug
//ssd1306_command( 0x22 ); // Set page start and end addresses
//ssd1306_command( 0x00 ); // start at zero
//ssd1306_command (0x07) ; // end at seven.
//DEBUG
ssd1306_command(SSD1306_DISPLAYON); //--turn on oled panel
