I know if you reverse + and - on a voltage supply you can measure a negative voltage using a multimeter, but for an op amp they only have one negative pin so I don’t think reversing + and - would work because you would be connecting the - voltage terminal to ground, I’m a little bit confused about how to achieve this, could you please explain how to get a - supply rail Thanks, Be
  • \$\begingroup\$ Choose Ground to be the V+ of an isolated converter to get V- out. Wherever you define 0V is "a local gnd". \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Nov 24 '17 at 5:23
  • \$\begingroup\$ you are incorrect with your statement about the multimeter. you measure a negative voltage when the multimeter positive probe is connected to a voltage that is more negative than the mutimeter negative probe. it is when you reverse the multimeter probes. ... the power supply voltages do not reverse. \$\endgroup\$ – jsotola Dec 18 '17 at 5:09
  • \$\begingroup\$ Do you even need a negative supply? Many op-amps will work from a single supply depending on what you are trying to do. \$\endgroup\$ – Finbarr Dec 19 '17 at 11:47
  • \$\begingroup\$ A negative supply needn't differ from a positive one. It is just connected with its positive terminal to ground. \$\endgroup\$ – Whit3rd Dec 19 '17 at 11:56
Use a DC-DC converter, a charge pump capacitive inverter or an inverting buck converter. Some type of switching supply is the easiest approach if you only have a positive rail available and actually require a negative rail.
There are easily available DC-DC converters that will accept a single DC voltage input and produce (say) +/-15V rails that are galvanically isolated from the input.
It's easier for your meter because it has an inherently isolated supply in the form of the battery.
If you are going oldschool you have to have two transformers or one with 3 output leads of which one is in the smack middle of secondary winding. Usually op amps require +/- 15 V DC. Now all you need is 7815 and 7915 ICs.
  • \$\begingroup\$ Hi koktelic, please include a reference/attribution for external content. I surmise it could be this one? \$\endgroup\$ – bummi Nov 24 '17 at 8:01
    \$\begingroup\$ "Usually op amps require +/- 15 V DC" in days long gone by maybe, certainly not true any more. \$\endgroup\$ – Finbarr Dec 19 '17 at 11:45
You may find this thread helpful.
Negative voltage from Arduino?
I would suggest you to do it with two batteries as shown below. However, your question lacks detail, so I can't recommend what would be the best possible solution for you.
    \$\begingroup\$ A bit of diligence here would have been desirable. The TL081 will not work with a +-1V supply. Also, this is probably the most cumbersome possible solution. \$\endgroup\$ – Marcus Müller Dec 19 '17 at 10:44
    \$\begingroup\$ Removed the 1V altogether. If by cumbersome you mean hard to implement I respectfully disagree. \$\endgroup\$ – user94729 Dec 19 '17 at 11:38
  • \$\begingroup\$ By cumbersome I mean merriam-webster.com/dictionary/cumbersome "because of heaviness and bulk" \$\endgroup\$ – Marcus Müller Dec 19 '17 at 11:44
