i have a Artix7 board with 4 SATA connector on it, i want to use these connectors for GTP transceiver, just connectors and i don't want to use SATA protocol, actually i do not know how to write XDC file for my SATA connectors, should i change the default xdc file? or the default xdc connects one tx to rx of other port? do i have to connect tx and rx myself?
  • \$\begingroup\$ External or internal transceivers? If they are internal, then look at the datasheet for the FGPA and it will tell you what your options are. If external, look at the schematic for the transievers and which pins they are connected to \$\endgroup\$
    – Voltage Spike
    Nov 28, 2017 at 0:22
The transceiver pinout is fixed, so if you want to use them, you are responsible for the physical layer wiring.
Your board documentation should show the pinout but you will probably find yourself needing to make a "Sata" crossover cable of some kind.
