Here is the datasheet that I have a question about. http://www.ixysic.com/home/pdfs.nsf/www/CPC1907B.pdf/$file/CPC1907B.pdf
It states in the Features List on first page. "Arc-Free With No Snubbing Circuits"
Does this mean that I do not need to add a Diode in reverse Parallel with my load? And it will be fine without it? I am driving an Inductive Load. 12VDC Motor Brake. 2-3amps.
There are no example circuits in Datasheet.
  • \$\begingroup\$ sounds like marketing hype. \$\endgroup\$ Commented Nov 25, 2017 at 8:03
  • \$\begingroup\$ did you ever get an answer on what does it actually means? \$\endgroup\$ Commented Aug 13, 2022 at 23:08
You should use the catch diode.
You must not exceed the absolute maximum blocking voltage stated in the datasheet (60V at 25 degrees C) and without a diode you will almost surely exceed that voltage when you switch off a solenoid load.
Also minimize the inductance of the wires running to the load (keep them together and minimize the length).
