-1
I want to use the Raspberry Pi's 3.3v GPIO pins to control whether a 5v LCD screen is on or off. The Raspberry Pi has a 5v pin but it cannot be turned on or off using Python or similar. Only the 3.3v GPIO pins can.
Therefore, to do this I want to use a CD40109BE level shifter (datasheet) to shift the GPIO pin's voltage from 3.3v to 5v but I'm not quite sure how to connect it up.
Here's a schematic of what I want to do with the chip:
But how would I do it? What pins and components would I need to use? I tried the schematic from this answer but it didn't seem to work for me and I only want to use a single input and output.
Thank you
  • \$\begingroup\$ Welcome to EE.SE, Billy. You need to include a datasheet link for the LCD so we know what type of input it has. Please edit your post to include it there. \$\endgroup\$
    – Transistor
    Commented Nov 27, 2017 at 18:19
  • \$\begingroup\$ Hello, the LCD screen does not have a datasheet but here is a link to the product. amzn.eu/6OWDXoW \$\endgroup\$
    – Billy
    Commented Nov 27, 2017 at 19:09
    \$\begingroup\$ "I tried the schematic from this answer but it didn't seem to work" - that schematic should work if you put +3.3V on pin 1 and +5V on pin 16. Exactly how do you expect the output to turn the LCD on and off? (CD40109 output can only source ~0.5mA, so it could control a switch but can't supply power directly to the LCD). \$\endgroup\$ Commented Nov 27, 2017 at 19:13
That is an TC1602A-01T display and the datasheet was found by searching for "1602 LCD datasheet".
The CD40109BE is designed for shifting logic-level signals. In your case you want to switch the backlight on and off. Reading the datasheet reveals:
Figure 1. Datasheet extract. Note the warning!
The CD40109BE is not suitable for switching 100 mA.
Figure 2. R1 limits the current to a safe value. Q1 allows switching from a 3.3 V GPIO. Source: 1602 LCD backlight LED.
\$ R_1 = \frac {V_{SS}–4.1}{0.1 } \$
For a 5 V supply this would give R1 = 9 Ω. The nearest standard value is 10 Ω and this would be fine.
  • \$\begingroup\$ Thank you. This seems to be working except for the fact that when the LCD screen is off, it is ~3v when it should be 0v. 3v still shows the backlight. (nb: My R1 is 100Ω because I don't have any 10Ω resistors) \$\endgroup\$
    – Billy
    Commented Nov 27, 2017 at 20:59
  • \$\begingroup\$ (1) "... it is ~3v when it should be 0v." What is? Please reference the schematic. For example, "I measure 3 V between A and GND when the GPIO pin reads 0.2 V." (2) Put 3, 4 or 5 x 100 Ω resistors in parallel. \$ R = \frac {100}{n} \$ where n is the number of resistors. (3) What value is R2. (4) What transistor did you use? \$\endgroup\$
    – Transistor
    Commented Nov 27, 2017 at 21:21
