-1
schematic of circuit
I am trying to simply blink an led light using pic16f877a microcontroller. softwares i am using are, MPLABX IDE, MPLAB IPE and XC8 compiler. I use Pickit 3.5 programmer. My head-aching question is, i have no errors when downloading the .hex to microcontroller in the IPE programme (it says "Programming complete" and when verify --"Verify complete"), but the led not even light up. but when downloading the programme, i can see the led randomly blinks or keep lit for sometime, then when done programming, it goes off.
I've made sure,
-led working -connections are good -pic is new (although tried using it for three or four times)
I'm not sure -whether i'm using something called "signal diode" correctly as stated in here https://www.youtube.com/watch?v=HVQ4tj-D8jM. i am using IN4007 diode (to connect its cathode to the MCLR of pickit's output...
Code:
#define _XTAL_FREQ 20000000
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = ON        // Low-Voltage (Single-Supply) In-Circuit
Serial Programming Enable bit (RB3/PGM pin has PGM function; low-voltage
programming enabled)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit
(Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits
(Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit
(Code protection off)
void main(void)
    TRISB=0b00000000;
    PORTBbits.RB0=1;
    return;
UPDATED Code: (WORKING - only during 'connecting' period of pickit to MPLAB IPE software)
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
// CONFIG
#pragma config LVP = OFF         // Low-Voltage (Single-Supply) In-Circuit
void main(void)
    TRISB=0;
    while(1)
        PORTBbits.RB0=1;
        __delay_ms(50);
        PORTBbits.RB0=0;
        __delay_ms(50);
Components in my circuit breadboard,
-pic16f877a microcontroller + base
-led
-IN4007 diode (its cathode connect to MCLR of pickit's output)
-20MHz crystal oscillator (to CLKIN and CLKOUT of pic)
-2x22pF capacitors (for oscillator)
-330R resistor (for led from pin RB0)
-10k resistor (for IN4007 diode from MCLR of pickit's output)
-0.1uF capacitor (for IN4007 diode to connect to ground)
-jumper wires
-pickit3.5 connection
I tried using several microcontrollers like pic16f84a and pic18f452 also, following different tutorials on internet, but no luck. i really love doing this and i am not hoping to give it up.
Anybody please help, it will relieve a big headache! Thank you very much!**
  • \$\begingroup\$ Are you sure that the LED isn't active low? Try writing a zero. Also make sure you set the data direction register for port B (DDRB) to outputs. \$\endgroup\$ – Ron Beyer Nov 28 '17 at 13:09
  • \$\begingroup\$ I've changed the code such that RB0=1 and RB0=0, but when i measured voltage across the led, the slight voltage of about 0.05V remained constant. BTW, i am a beginner although i've done some electrical stuff back then. \$\endgroup\$ – stackUsr Nov 28 '17 at 13:18
  • \$\begingroup\$ @DiBosco, i've added a diagram. PS: i am not familiar with schematic designing and electronics at large. but i hope i have converted my circuit to an understandable schematic. \$\endgroup\$ – stackUsr Nov 28 '17 at 14:04
    \$\begingroup\$ One thing that occurs to me (sorry this is nothing to do with the hardware) is that your software should have: while (1); instead of return; I'm not sure what your processor will do when it hits the return; statement and what state it will put the pins in. \$\endgroup\$ – DiBosco Nov 28 '17 at 14:11
  • \$\begingroup\$ I reckon D2 is completely unnecessary BTW. \$\endgroup\$ – DiBosco Nov 28 '17 at 14:13
I have found a solution:
  • I closed MPLAB IPE completely.
  • Then from project properties of MPLABX IDE, I selected the needed power and selected option to power the target from PICkit3.
  • Then "made" the program.
  • To run it, clicked on "Release from Reset".
IT WORKED!!! Now the LED blinks like COOL!!! Headache cured!
  • \$\begingroup\$ You can accept your own answer to indicate the correct solution to your question. Thank you for posting the solution. +1 \$\endgroup\$ – Transistor Nov 28 '17 at 18:20
  • \$\begingroup\$ When I get to the point where I can ask an intelligent question, I usually can find a solution. +1 \$\endgroup\$ – StainlessSteelRat Nov 28 '17 at 18:41
