I am looking for a way to measure the pressure on a push button when it is pressed. I intend to save it in flash of a microcontroller.
Please let me know if you know any device which could be useful.
Thanks,
  • \$\begingroup\$ You probably should use a pressure sensor for that. \$\endgroup\$ – Michel Keijzers Nov 28 '17 at 14:01
    \$\begingroup\$ Do you want the actual pressure (force per unit area), or just the total force? If the latter, the sensor you want is called a "strain gauge". But you need to be a lot more specific about what you need: the range of force (or pressure) you expect to see, the accuracy and sample rate (bandwidth) you require, and any other constraints imposed by the application. \$\endgroup\$ – Dave Tweed Nov 28 '17 at 14:02
  • \$\begingroup\$ I believe hall-effect buttons and switches give you some feedback about how hard or fast the button is pressed. \$\endgroup\$ – Trevor_G Nov 28 '17 at 14:05
  • \$\begingroup\$ Wondering what pressure on a button has to do with flash in a micro.... \$\endgroup\$ – Trevor_G Nov 28 '17 at 14:09
    \$\begingroup\$ sparkfun.com/products/9673 \$\endgroup\$ – Bruce Abbott Nov 28 '17 at 14:52
You could use a force sensitive resistor like this one.
Or perhaps a linear hall-effect push button like this one.
Use a rubber button with some 6mm airline pipe to a pressure sensor connected to microcontroller.
  • \$\begingroup\$ Thanks for your reply! If you know any manufacturer name, that has the product, could you let me know. I tried searching using keywords from your reply but could not find anything. \$\endgroup\$ – gabbar Nov 29 '17 at 13:18
  • \$\begingroup\$ It will take some searching the simplest solution would be a pnuematic button such as in use on toilets some even look like simple buttons however pnuematic buttons do exist however you would have to come up with a solution to allow continuous use as once pressed any pressure would go to atmosphere, hydraulic buttons exist which may be suitable however costly if you really want a simple solution a plastic syringe some 5mm airline tubing and I would use the mpx2010dp differential pressure sensor which is cheap and readily available with a 5 volt output. \$\endgroup\$ – Chris James Nov 29 '17 at 17:41
  • \$\begingroup\$ RS Components stock many of the items described a quick Google search will return many also ebay another source. \$\endgroup\$ – Chris James Nov 29 '17 at 17:42
This is such an awsome questions with many creative solutions!
  • Use a coil-based button with spring,
  • Measure hum.
  • Based on mounting, use flex in pcb or hole with strain gauge.
  • Body heat.
There must be tons of ways. Just add to the list.
