I have a project that requires me to make a portable power pack that can be charged up and then power different devices. The product needs to have two USB charging ports and hold around 7Ah.
The problem I have is that the devices it will charge vary in minimum/max current and voltage and I would like to not damage the devices it is charging. What is the best way to do this as the only way I would know is to state the rails, yet I cant list all the devices it could charge so should I go for a general voltage and current.
Also what are some of the important circuits I should be looking to make sure the device has to make it more safe. Any answers are appreciated
  • \$\begingroup\$ If you're charging devices via USB ports you just give them 5V and let them take the current they need. \$\endgroup\$ – Finbarr Nov 28 '17 at 16:11
If you are using a USB 2.x connector then you should supply only 5 V.
Configuration of the D+/D- lines can advise of the peripheral charging current required. If you don't use these lines then you will simply provide the current defined by the peripheral.
If you are using a USB 3.x connector then you can negotiate the output voltage based on the connected peripheral device.
This answer provides a starting point for your research. Short answer.... read the USB 3 spec.
| improve this answer | |
