I have an M24C01-x EEPROM (1 KBit in size) driven by an STM32. The datasheet doesn't make it clear what the page size of that EEPROM is. I require it to properly configure the STM32 EEPROM driver.
How can I calculate/know the page size of the M24C01-x?
  • \$\begingroup\$ Isn't it mentioned on page 14? The page size is 16. \$\endgroup\$ – Rocketmagnet Jun 20 '12 at 9:23
The page size is 16 bytes, as stated in the datasheet.
The Page Write mode allows up to 16 bytes to be written in a single Write cycle, provided that they are all located in the same page in the memory: that is, the most significant memory address bits are the same. If more bytes are sent than will fit up to the end of the page, a condition known as ‘roll-over’ occurs. This should be avoided, as data starts to become overwritten in an implementation dependent way.
Page 14.
So your 1KBit memory has 8 pages, each 16 bytes in size.
Page 14 of the datasheet:
So a page appears to be 16 bytes.
