We are planning to use this power-line-filter to reduce the possible power line noise in our data acquisition system. And the data-sheet as pdf can be downloaded from here.
The data sheet shows the wiring diagram of the filter as follows:
But I was planning to use this filter for PC and many transducers ect. by also maintaining the safety.
So for my question I have drawn the following:
As you see above if I use this filter between the power outlet and the power strip as in 2nd figure, the earth connection(yellow-green wire) no more exists after the filter. I have equipment which is chassis grounded to earth for safety.
Wouldn't it be risky to use this filter since earth wire cannot be used anymore for safety? Does anybody have experience with such application and filters?
