I have a LVDS clock signal that is gated about ever 30us. This is a MIPI D-PHY clock that switches from HS mode to LP mode when the data lanes go to LP mode (and are auto-clocked). The problem is that my receiver circuit does not support this and expects the clock to always be running so I wish to build some sort of buffer circuit that "continues" the clock in those periods where it is turned off.
Here is what the input signal looks like:
In the time when the input clock is on, I wish to have low propagation delay (ideally passing the input clock right through). However, when the input clock is off, I want the output clock to continue at the "last seen frequency"--skew does not matter much. Once the input clock comes back up, I want it to match the phase again. From the D-PHY standards, I think I have 85ns + 6 clock periods to do this.
A potential solution I thought of is to use a 2:n clock buffer with a select pin along with a PLL. The output of the buffer will be the PLL (and my application) and the inputs of the buffer will be the source clock and the PLL output. Then I can set the select pin to my DCLK+ so it will automatically select the PLL when it goes high. Will this work or is there some obvious problems?
