6
I have two very similar eeproms (M24C01-x and M24C64-x), both driven by the same standard library provided for my STM32F2.
For the M24C64-x, all is fine. However, the M24C01-x is interpreting the address byte of a write transaction as a data byte, and can only write on the first page. (Reads work fine.)
A quick look through the datasheets reveals that the main difference between the chips is that one has a 16 byte page size, and the other a 32 byte page size, which I have accounted for.
What difference between these two eeproms could cause the standard library driver to break down and behave in this manner?
Look at Figure 7 in the M24C01 datasheet and Figure 9 in the M24C64 datasheet.
The M24C01 only takes one byte for the address and the M24C64 takes two. So the library you are using is sending out a two byte address to the M24C01.
You didn't specify the library you are using. Are you able to specify the address width?
  • \$\begingroup\$ Brilliant! That probably explains the discrepancy in results. Thanks a lot! \$\endgroup\$
    – Randomblue
    Commented Jun 20, 2012 at 16:29
