In my design, I wanted to use a number of counters with different initial values on reset. Therefore I defined the counter module as follows:
module my_counter #(parameter int INIT_VALUE = 0)
input clock, reset,
Then in the design I have 4 instances of mycounter
that share a lot of inputs, but have different initial values. I'd like to make them a module array, but the best way I've come up with is:
defparam my_counters[0].INIT_VALUE = 0;
defparam my_counters[1].INIT_VALUE = 1;
defparam my_counters[2].INIT_VALUE = 2;
defparam my_counters[3].INIT_VALUE = 3;
my_counter my_counters[3:0](
.clock(clock),
That works with simulation, but I've heard that defparam
is considered poor form. Furthermore, when trying to synthesize my design, the synthesizer complains that Syntax error at or near token '['.
on the lines with defparam.
How could I do what I wanted to do without a lot of code duplication?
