So based on the responses from this thread: Ethernet Interface PCB layout requirement (if any) I made an Ethernet interface layout the best I possibly could using 2 layers.
The circuit is of the following:
*the ethernet jack I am using has a different pin out than the one shown in this schematic so pay no attention to that. enter image description here
I have separated the ground layers of the signal traces from the rest of the circuit. Also I have added an additional ferrite bead connecting the signal grounds to AGND. My thinking was that this would further isolate the signal traces and since they are differential there should not be any DC current to AGND anyway. enter image description here
How is this layout scheme? Is it satisfactory? Is the ferrite bead to AGND a good or bad idea?
  • \$\begingroup\$ Did you have a question? \$\endgroup\$ – Dampmaskin Dec 4 '17 at 12:15
  • \$\begingroup\$ The layout doesn't correspond to the schematic. What is the square thing with 6 pins on top? \$\endgroup\$ – peufeu Dec 4 '17 at 12:54
  • \$\begingroup\$ read line 5. The 'square thing' is the bottom of a ENC28J60. If I were to put in the whole footprint you would not be able to see the TPIN/TPOUT traces which are the ones that are sensitive. I clearly labeled these traces in the picture so that matching these to schematic nets should be obvious. \$\endgroup\$ – Tony Dec 4 '17 at 13:15
  • \$\begingroup\$ Oh, you mean the ENC is in DIP package? \$\endgroup\$ – peufeu Dec 4 '17 at 13:20
Don't split the grounds: use a solid ground plane instead. This elaborate splitting of grounds will only add extra ground impedance and worsen performance, noise immunity and emissions. Just don't.
The rest of the passive components should be SMD. I find it weird that you use a SMD magjack and then thru hole passives. If you're not used to SMD, pick 1206 size, they are very easy to work with.
The best place to put the passives is between the magjack and the ENC chip. It is a rather natural placement. If that doesn't fit, you can leave them where they are too (the transmission line stubs won't matter at 10Mbps).
There is no "AGND" in your schematic, nor ferrite bead between the grounds, so this is unclear. If that is what I think it is, according to the PCB layout, the ferrite bead will disconnect output transformer center tap from GND at HF and thus decrease performance, expect increase in common mode noise on the cable. So, no need for this ferrite bead.
The most important thing is to use a proper solid ground plane.
| improve this answer | |
  • \$\begingroup\$ Thank you! The SMD magjack was used because it was easier to route. The TO version made it very difficult to keep the traces the same length especially for 2 layers. I try to avoid using SMD components as much as possible cause it makes it harder for the tech. I'll will switch up the design if it is required for good operation. \$\endgroup\$ – Tony Dec 4 '17 at 13:51
  • \$\begingroup\$ Well for 10Mbps you thru hole passives should work fine (it's just that in CURRENT_YEAR they seem unusual!)... just make sure to use a solid ground plane. \$\endgroup\$ – peufeu Dec 4 '17 at 14:01
  • \$\begingroup\$ Re SMD vs TH: I agree that TH should be fine. However, be careful when hand soldering SMD ceramic caps, as they can crack (without visually-obvious signs), and cause headaches. There are newer SMD cap designs that help mitigate this issue. \$\endgroup\$ – Chris Knudsen Dec 4 '17 at 16:23
    \$\begingroup\$ It Works!! Thanks guys. imgur.com/a/TguFE imgur.com/a/fgz7L \$\endgroup\$ – Tony Dec 28 '17 at 11:47
