I'm designing my first schematic in Eagle, with the aim of getting some PCBs produced. Been perfboarding for a while, but new to using Eagle.
I've designed a schematic:
I know it's kind of messy, but as far as I can tell everything is matched up. Now you can probably see more than one V+ pads. The one on the far left and the one on pin 4 of the IC are V+, and that middle top one is actually VA. When I generate the board, it gives me a pad for every instance of it, instead of just one. Is there a way round this? You can probably make out the red hatching on the bottom right two pads on the board here (power and ground)
Any help or even feedback on my schematic appreciated!
  • \$\begingroup\$ I don't know Eagle, but most schematic capture tools will need you to label two nets with different names if you don't want them connected to each other. \$\endgroup\$ – The Photon Dec 4 '17 at 21:45
  • \$\begingroup\$ I do want them to connect to each other, and both nets are called V+, but it gives me two pads to place on the board instead of one. \$\endgroup\$ – TCassa Dec 4 '17 at 21:48
  • \$\begingroup\$ You have to use other supply symbols which do not produce a pad. The ones which resemble arrows do not. Oh, and fix R4 and run an ERC before starting the layout phase. \$\endgroup\$ – Janka Dec 4 '17 at 21:50
  • \$\begingroup\$ Eagle Supply symbols don't give a pad on the PCB editor. It may be that you placed two "test-points" or something like that, therefore have 2 pads. \$\endgroup\$ – Wesley Lee Dec 4 '17 at 21:51
  • \$\begingroup\$ Friendly advice : don't use the auto router \$\endgroup\$ – Mike Dec 4 '17 at 21:56
