I want to store a variable every time a breakpoints is hit, while i am running a test. Any idea how can i automate the task??
Or How can we monitor keil via python or any other script language ?
You can use the Breakpoint dialog to run commands when you hit a breakpoint.
keil breakpoint dialog
| improve this answer | |
  • \$\begingroup\$ I have one more question , i am saving a variable by "SAVE temp1.hex temp_array,&temp_array[0]+sizeof(temp_array)" . if i want to increment temp1.hex at hit how to achieve same?? \$\endgroup\$ – yogesh singh Dec 5 '17 at 8:07
  • \$\begingroup\$ @yogeshsingh You could call a function that selects a different hex. This is far beyond how much time I've spent in debug commands. Sorry. \$\endgroup\$ – Jeroen3 Dec 5 '17 at 9:01
