If I have a signal generator with 600 ohm output resistance and a 8 ohm speaker. The number of turns in primary coil is 50, so the turn ratio should be $$\frac{600}{8}=(\frac{N_2}{50})^2 \\N_2=433\\N_1:N_2=50:433$$ Furthermore, will there be any difference on maximizing the power output with applying different frequency output in the signal generator!? such as 1khz vs 5khz.
You've got it backwards. You have a 600 Ω signal and want to drive a 8 Ω load. Apparently you are trying to do this with a transformer between the two. Clearly the primary needs to have the higher number of turns.
Your resistance ratio is (600 Ω)/(8 Ω) = 75. The turns ratio needs to be the square root of that, which is 8.66. (50 turns)/8.66 = 5.8 turns. That's what the secondary should be.
