electric scheme
I want to model electric scheme in OrCAD from an image and I stuck on element K1 (surrounded by the red rectangle). What is this element, why do we need it, and can I find it in standard OrCAD library?
K1 is a relay coil. The coil is the black rectangle and the contacts are on the right (K1.3=NO/K1.2=COM/K1.1=NC). VD2 is the flyback or catch diode.
K is usually used for relay names on schematics.
  • \$\begingroup\$ Is there any library with this element? \$\endgroup\$
    – Kiramm
    Dec 5, 2017 at 20:36
  • \$\begingroup\$ There are relays in Orcad, or you can download a specific one, I usually use SnapEDA. \$\endgroup\$
    – Ron Beyer
    Dec 5, 2017 at 20:37
  • \$\begingroup\$ They might look differently. \$\endgroup\$
    – Eugene Sh.
    Dec 5, 2017 at 20:48
  • \$\begingroup\$ Right, there are a number of different ways to represent a relay on a schematic, but how they work is the same (as long as it has same electrical characteristics). \$\endgroup\$
    – Ron Beyer
    Dec 5, 2017 at 20:49
