I am trying to learn altium.I just placed stm32f407vg microcontroller and one resistor these gives me error as in the picture :
(Failed to add the class and unknown pin error) http://oi68.tinypic.com/28hzbeu.jpg
  • \$\begingroup\$ do you have a footprint defined for the resistor? \$\endgroup\$ Dec 6, 2017 at 7:24
  • \$\begingroup\$ yes I am actually using standary altium Res3 \$\endgroup\$
    – Qwe Qwe
    Dec 6, 2017 at 7:54
  • \$\begingroup\$ Probably the footprint is not defined for it. Open Footprint Manager window via Tools -> Footprint Manager menu item. In the window, find and select the resistor from the Component List to the left then see if there's a footprint is defined or not. \$\endgroup\$ Dec 6, 2017 at 8:32
The resister footprint is not matching with your schematic.In the schematic, the resistor R1 terminals were named like R1-1 and R1-2.But, footprint pads name not 1 and 2.Thats the problem.
Go to the corresponding library and Edit the footprint pad name.Then it will be Okay.
