I've an old and cheap Atten TRP3005T Take a look at atten site
I have seen more expensive device that had a specific button that always disable the current emission every time you power off the device.
This is a security feature to avoid disastrous error when you attach a device to the power supply when the power supply is off and has been left to wrong settings (happen to me.. but without consequences... 15 volts on an Arduino when I want to use only 9 volts to test it)
Is there a way to add the same feature to my power supply ?
I think that I need to build a circuit with a dual mosfet but I'm not enough skilled to design it by myself... Also I'm not sure if this option draws power from the power supplier and can make some strange side-effects to power output like wrong value for voltage.
  • \$\begingroup\$ A relay with a latching power input would work. \$\endgroup\$
    – Passerby
    Dec 6, 2017 at 18:16
  • \$\begingroup\$ Hi @Passerby, i also check for relay with latching power input (is where i understand that i need a dual mosfet :P ) but i can't find anything suitable for my needed.. solution closer to what i need is probabily this: bit.ly/2ixnD2y found here: bit.ly/1Kju2ag but if i understand correctly has a current limit of 26V where my device can supply 30V also seem there is some sort of draining where is operative is this right? \$\endgroup\$
    – Marco
    Dec 6, 2017 at 18:31
  • \$\begingroup\$ Trevor provided a good way of you do this internally. You are already modifying it. Externally, you could add a voltage regulator to provide the relay power. Yes it would take current from the supply, which you could measure and subtract from your reading. Or provide a second external supply that you need to switch at the same time as your bench supply. \$\endgroup\$
    – Passerby
    Dec 6, 2017 at 19:22
If you can figure out the internals of your power supply, adding a relay and a momentary push-button is a fairly simple task, perhaps with an added LED for feedback. (Or an illuminated momentary push button I guess.)
Once it's on it would stay on till you turn off the supply though, but you can add a second, normally closed button to disconnect.
If the Lab supply has a large storage Cap that floats when AC is switched off, you want an LED charge indicator which also slowly discharges the cap. Choose 40mA for 30V with a couple UB LEDs White and Red using 2 current limiting Rs=1.4k .
Or better if you actually want an active Low to ground to enable a High Side 30V Smart switch. (this one may not be reliable << 5V although it has a charge pump for Vgs.)
The simplest solution that I can think of, using switched AC inside PSU with Relay and Lamp mounted inside.
