I was trying to design a TFF in VHDL. I wrote the code below
library ieee;
use ieee.std_logic_1164.all;
entity TFF is
  port(
    T: in std_logic;
    clk: in std_logic;
    Q, Qn: out std_logic
end entity;
architecture behavior of TFF is
signal q_state: std_logic := '0';
begin
  process(clk)
  begin
    if clk'event and clk = '1' then
      if T = '1' then
        Qn <= q_state;
        q_state <= not q_state;
        Q <= q_state;
      end if;
    end if;
  end process;
end behavior;
Then I used Modelsim to simulate the code. While testing I noticed that Q and Qn are the same. I wonder why this happend.enter image description here
    \$\begingroup\$ It's clocked logic. There isn't an order like in C. If T=1 and there is a positive clk edge than those 3 things happen simultaneously. \$\endgroup\$
    – ACD
    Dec 6, 2017 at 19:13
  • \$\begingroup\$ I thought the code in process part will run sequentially. isn't it like that? \$\endgroup\$ Dec 6, 2017 at 19:15
  • \$\begingroup\$ Because signal assignment semantics. stackoverflow.com/questions/13954193/… As an experiment, try making q_state a variable, local to the process... \$\endgroup\$
    – user16324
    Dec 6, 2017 at 19:52
Q <= q_state;
You coded this, assuming that q_state is complemented immediately and it will be assigned to Q. But actually in VHDL, all signals are scheduled to be updated only at the end of the process (known as delta delay), and the changes will be reflected only in the next process execution or simulation cycle.
Here q_state was 0 initially. q_state <= not q_state statement schedules q_state to be 1 for the next simulation cycle. Current value remains at 0 itself. So when Q <= q_state is executed, 0 is copied to Q, not 1. In the next clock edge, new value of q_state is available. Now if you analyze, you can see that both Q and Qn will continue to hold the same value in every clock cycle.
    \$\begingroup\$ You can use variables, if you really want these kinda immediate assignments somewhere in the code. :-) \$\endgroup\$
    – Mitu Raj
    Dec 7, 2017 at 20:08
A simpler and more direct implementation would be:
library ieee;
entity TFF is
  port(
    CLK     : in  std_logic;
    RST     : in  std_logic;
    T       : in  std_logic;
    Q       : out std_logic;
    Q_N     : out std_logic
end entity TFF;
architecture behaviour of TFF is
  signal tState      : std_logic;
begin
  pFlipFlop : process(RST, CLK) is
  begin
    if (RST = '1') then
      tState  <=  '0';
    elsif (CLK'event and CLK = '1') then
      if (T = '1') then
        tState  <=  not tState;
      end if;
    end if;
  end process pFlipFlop;
  Q    <=      tState;
  Q_N  <=  not tState;
end behaviour;
but this introduces a delta delay onto Q_N which may be a problem if this feeds another CLKed flip-flop input.
Alternatively, you could use the below but it may implement more than one flip-flop, though synthesis optimisation should reduce it to one.
library ieee;
entity TFF is
  port(
    CLK     : in  std_logic;
    RST     : in  std_logic;
    T       : in  std_logic;
    Q       : out std_logic;
    Q_N     : out std_logic
end entity TFF;
begin
  begin
    if (RST = '1') then
      tState  <=  '1';
      Q       <=  '0';
      Q_N     <=  '1';
      if (T = '1') then
        Q       <=      tState;
        Q_N     <=  not tState;
      end if;
    end if;
end behaviour;
  • \$\begingroup\$ Both your examples are missing declarations for tState and qState. The identifier t may not be used in a signal declaration, it is a port of mode in. \$\endgroup\$
    – user8352
    Dec 6, 2017 at 20:51
  • \$\begingroup\$ As I imagine you noticed @user8352, it was a typo' calling the signal 't', not 'tState' as intended. Thanks for calling it, fixed now :-) \$\endgroup\$
    – TonyM
    Dec 6, 2017 at 21:10
  • \$\begingroup\$ And what of qState? \$\endgroup\$
    – user8352
    Dec 6, 2017 at 22:01
