I have a DAC connected to an FPGA, which I cannot get to work. The FPGA, in a loop, sends in the maximum value to the data pins and incrementally goes down to 0.
I have checked with a scope that the data pins are changing as expected, and I have checked that the clock is OK. Nevertheless, the output analogue signals IOUTA
and IOUTB
stay constant (around 1V).
The DAC can be configured through an SPI channel, but the default configuration should work out of the box. What could I be doing wrong for my DAC to stay constant despite the data pins changing?
SELECT
is high and therefore routing toIOUT
? Just something to check that you didn't mention. \$\endgroup\$
