I don't know how to interpret the voltage values found in datasheets for transformers. For example, in the datasheet below:
where it says 15v, 50mA near the winding schematic. Is this a maximum or a test condition or nominal value? Is there generally a maximum output voltage for a transformer other than the dielectric breakdown voltage which is in this case specified at 1500V? Do i have to respect something like not go above 50mA*15V watts? If i want to use this transformer at an output of 75-100V for each of the 2 secondaries will i run into problems? How can i make sure the output of a flyback converter using this transformer is not too high, using the information provided in the datasheet?
