I want to have two switches controlling my lights room that works like a XOR gate, does anyone know how to do it? I have a very simple switch for testing and I tried many times and couldn't do it as I don't know too much about electronics.
This is the switch I am using:
I was wondering if there is a way to wire it to another one that looks the same that works like a XOR gate.
I found this diagram online but I don't understand it, here it is though:
Cheers.
While this won't work well in the case of your room lights it does show a means of lighting an LED using your switches. This could be used to drive an opto-isolator triac, etc., if you really had to use those switches.
Figure 1. An XOR configuration to control a small LED load using two SPST switches.
How it works:
  • With both switches open both sides of the bridge rectifier are connected BATT+ by R1 and R2. The LED will not light.
  • With both switches low both sides of the bridge rectifier are pulled low. The LED will not light but > 10 mA will flow in each switch for no optical benefit.
  • If either SW1 or SW2 is closed current will flow through the LED.
Figure 2. If SW1 is closed current will flow through R2, D3, LED D1, D4 and SW1.
| improve this answer | |
You need two SPDT (single pole, double throw) switches. A SPDT switch will have three terminals - your two-terminal switch won't work.
The animated diagram you show is what you want.
EDIT (after OP's comment)
This is the required circuit:
If both switches are up, or both are down, the lamp will light. If the switches are in opposite positions (one up, the other down) the lamp will be off.
A single SPDT switch and a relay won't work, since your original question required two switches.
  • \$\begingroup\$ Would it work with a relay and a SPDT? instead of 2 SPDT. And can you show me how to wire it because I don't understand the diagram too well. \$\endgroup\$ – Matthew Dec 9 '17 at 17:40
  • \$\begingroup\$ You could use two SPDT relays controlled by two SPST switches. Or one of each, but the contacts at both ends need to be SPDT. \$\endgroup\$ – Spehro Pefhany Dec 9 '17 at 19:10
  • \$\begingroup\$ This is (one form of) the classic two way switching circuit used routinely by electricians. I'd never thought of it as an XOR gate, but of course it is! \$\endgroup\$ – Ian Bland Dec 10 '17 at 1:33
