I've come across this question at work and it has stumped me... even though it is quite basic.
A distribution board is supplied by 3 phase 415 AC power. From the distribution board to a circuit breaker, only 2 of the three phases are used, and the other phase is grounded.
A RCD is to be installed after the circuit breaker. Is the power that the RCD to receive considered 3 phase with an asymmetric fault, with 415v between phases and 240 between phase and neutral?
Or is it split phase power? with 240 between phase and neutral and 480 between phases?
