33
When opening up a car alarm system I found this strange-looking component. I thought that it could be something which is light dependent, but the entire board is enclosed in a black plastic box and the alarm should trigger before the thief reaches the depths of the electric system and thinks of opening it.
Here are some photos: enter image description here enter image description here enter image description here enter image description here
What component is this?
94
It's a piezoelectric disc buzzer with a weight. It's being used as a vibration sensor, not a sound generator.
The weight amplifies the strain produced by vibration.
    \$\begingroup\$ @DanielTork: To amplify the strain produced by vibration. \$\endgroup\$ Dec 10, 2017 at 10:24
    \$\begingroup\$ So, it triggers the alarm in the event of physical tampering, right? \$\endgroup\$
    – voices
    Dec 10, 2017 at 18:13
  • 4
    \$\begingroup\$ @tjt263: Not necessarily triggers, but it lets the device know that it's a possibility. There are various things that can cause vibration and it's up to the circuit to figure out what is going on. \$\endgroup\$ Dec 10, 2017 at 18:48
  • 7
    \$\begingroup\$ The weight idea is really cool -- it lowers the frequency of oscillation that the piezo will be sensitive to into the range that the car might vibrate. \$\endgroup\$
    – Dave X
    Dec 10, 2017 at 20:10
    \$\begingroup\$ @DaveX I'm with DaveX here. The weight modifies the resonant frequency; it doesn't amplify (how could it; it's passive). \$\endgroup\$
    – Kaz
    Dec 12, 2017 at 0:31
16
My answer is an educated guess.
It looks like a vibrating plate that is activated when the vehicle is shaken or something like that. On the plate, in the centre, you find a piezoelectric element converting the mechanical movement into an electrical one. From there on it should be clear.
Seems piezo electric component that vibrates when a specified vibration applied . It creates a necessary clock pulse required for the PIC IC to turn on then pulse conversion from digital to analog to creates sound . Only a guess from me .. thanks
    \$\begingroup\$ Good suggestion, but usually a clock (often a crystal) deals with that. \$\endgroup\$
    – wizzwizz4
    Dec 11, 2017 at 21:11
