I have a Problem turning a MOSFET On/Off with my Arduino. I try to controll multiple mosfets to supply a high power Device with current. Now my issue is that the mosfet does not turn on. Here is a basic sketch of the circuit for one MOSFET. sketch
I use this mosfet
At this point, I am not sure if the 5V supply Voltage is enough to switch the MOSFET. The max. VDD is 200V and 1A
I tried adding a Bleed Resistor at 10k Ohm but that didn't really change anything.
The Analyzer is my Supply and measures the Current/Voltage.
The Analyzer is A B1500A
It can measure spot, sweep, sampling and pulse in the range of 0.1fA-1A or 0.5uV-200V
    \$\begingroup\$ Well, check the datasheet of the mosfet what voltage you need... \$\endgroup\$
    – PlasmaHH
    Dec 11, 2017 at 13:03
    \$\begingroup\$ Looks to me like your load is in the wrong place. It should be connected to the drain of your MOSFET, not the source. Also, if you're not using a 5V micro, you're not guaranteed to turn it on with that FET. \$\endgroup\$
    – DiBosco
    Dec 11, 2017 at 13:07
  • \$\begingroup\$ VGS(th) is 2V to 4V. Or are you saying i have to supply VGS(10V)? \$\endgroup\$
    – seppdepp3
    \$\begingroup\$ The source to gate threshold is where there is 250 microamps drain current; this is not where the channel has been fully enhanced. Rds(on) is specified at 10V only. \$\endgroup\$ Dec 11, 2017 at 13:43
First, you can not use an N-Channel MOSFET like that to high-side switch power to a load. The gate voltage would been to be greater than Vdd when the thing is turned on.
N-Channels are better suited for low-side switching, as shown below.
Second, even if properly configured as a low side switch, that particular device is only guaranteed to start turning on at 4V, which will be marginal with a 5V Arduino, and way too high for a 3.3V model.
If you really need to use high side switching you need to use a two stage switch like this one.
However, switching 200V at higher speeds is not that easy.
In all cases you need to include an appropriate gate resistor to limit the current required from the Arduino to switch the MOSFET and to provide a little isolation from voltage spikes.
  • \$\begingroup\$ Thank you, i use the MOSFETs to supply an IGBT that should be tested. So i have one MOSFET for each pin of the IGBT-Module. I wasn't sure if these would then be high-side or low-side since the load does not exist if the IGBT conducts. \$\endgroup\$
    – seppdepp3
    Dec 11, 2017 at 13:24
  • \$\begingroup\$ @seppdepp3 for something like that it sounds like you would need "half-bridge circuit"s that can do both high side and low-side switching. But be careful, 200V is not something to be toyed with and the current you are talking about will be LARGE. \$\endgroup\$
    – Trevor_G
    Dec 11, 2017 at 13:28
  • \$\begingroup\$ Okay, i was of the opinion that since i only supply "in one direction" i would not need a half-bridge. I added a baisc circuit to my question. The Analyzer limits my current to a max of 1A. \$\endgroup\$
    – seppdepp3
    Dec 11, 2017 at 13:42
  • \$\begingroup\$ @seppdepp3 that schematic is pretty meaningless if you do not supply full specs on the "analyzer". It is also totally wrong and should be a new question. \$\endgroup\$
    – Trevor_G
    Dec 11, 2017 at 13:44
  • \$\begingroup\$ Okay, i added the details but i don't want to take to much of your time so thank you very much. \$\endgroup\$
    – seppdepp3
    Dec 11, 2017 at 13:51
