Assume I want to have a continous sine signal as input to my VHDL code. The values will be of type float since it will take on non-integer values for example: 10.5 mA.
How do I manage these numbers in my VHDL code?
I have tried to use: type Voltage_Level is range -5.5 to +5.5;
as an example but it did not work since i couldn't import signed vector into Voltage_level since Voltage_level must be represented as a signal.
I would appreciate if someone could help with these kind of issues? What is the most easiest way to deal with this?
The basic problem is when I input non-integer values, say 10.5 and try to use the same value as input the FPGA outputs a rounded integer, in this case 10. So it seems that I can use VHDL only when i deal with integers and bit vectors, which is very limiting use scenario. Especially for people like me that work a lot with various kinds of signals.
subtype Voltage_level is real range -5.5 to 5.5;
