I need to draw a round hole on a polygon pour.
I've followed this documentation (see video in "Subtracting Selected Polygon Pours" paragraph). It explains that you must first selected the reference polygon and then all the polygons you want to "remove" from the reference polygon.
My concern is that I can't select the other polygons while they are fully inside the reference polygon. If I click using the shift key. It deselect the reference polygon...
How to do that?
Edit: I need to remove the highlighted circle from the disk but not the other copper region:
Starting from this: enter image description here
to this: enter image description here
  • \$\begingroup\$ One way would be through the polygon manager I guess? \$\endgroup\$ – Wesley Lee Dec 11 '17 at 19:28
  • \$\begingroup\$ What Altium version? I think they have mucked up the interface to select one of an overlapping set of objects in the most recent versions. \$\endgroup\$ – The Photon Dec 11 '17 at 19:47
  • \$\begingroup\$ version 16.0.5 . \$\endgroup\$ – Julien Dec 11 '17 at 19:56
  • \$\begingroup\$ Draw a circle using primitives on whatever layer you want, then select the circle and go to Tools -> Convert -> Create Cutout from Selected Primitives \$\endgroup\$ – DerStrom8 Dec 11 '17 at 20:01
  • \$\begingroup\$ *Then just delete the original primitives \$\endgroup\$ – DerStrom8 Dec 11 '17 at 20:19
Hold shift and left click on all the polygons, then let go of shift and right click on the poly you want the others to subtract from. The right click should give you a list where you can select (with left click) the subtract command.
  • \$\begingroup\$ I can't see the menu, you're talking about.... screenshot \$\endgroup\$ – Julien Dec 11 '17 at 19:55
OK, here's what I did:
Convert center circle to polygon pour, put it in the right position in polygon manager, repour, convert big disk to free primitive, delete center disk. This must be done when everything is done because, repouring cannot be done anymore on the big disk. enter image description here
