Can anyone identify these two ICs from a laptop motherboard?
closed as off-topic by Lior Bilia, Nick Alexeev Aug 4 '18 at 4:07
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – Lior Bilia, Nick Alexeev
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ forgot to mention that this is a laptop motherboard. \$\endgroup\$ – Ian Douglas Dec 12 '17 at 8:24
    \$\begingroup\$ Considering everything points to these being power supply ICs: if they have failed, they've with a high likelihood fried something else, too. That's not absolutely certain, but if you're assuming that "just" replacing these ICs will fix your notebook: expect to research much deeper. \$\endgroup\$ – Marcus Müller Dec 12 '17 at 10:30
It seems to be a step down controler. You can find here the datasheet : datasheet.
For replacements, I invite you go on the TI power supply test bench and simulate the need of your circuit. The website will advise you the proper chip. Link here
