How to find out the voltage v3 in the following circuit using mesh analysis? enter image description here
I tried to solve it by considering the dependent current source as a super mesh and eliminated it.
The equations I got are:
8 - 6*i1 + 2*i2 +3*i3 = 0 ------------ this equation belongs to the loop that contains 80 V source.
30 - 70*i3 + 50*i1 -20*i2 = 0 --------- this belongs to the loop that contains 30 V source.
15* i1 - i2 + i3 = 0 --------- super mesh equation
The current values I got after solving the equations are:
i1 ~ 0.95A
i2 ~ 11.35A
i3 ~ -2.9A
which translates to V3 = 40 * i3 = 116 V
But the solution in the book says V3 = 104.2 V
Can somebody please tell me where did I go wrong?
    \$\begingroup\$ Homework questions with no attempt at a solution are closed. \$\endgroup\$ Dec 12, 2017 at 15:59
    \$\begingroup\$ @LeonHeller Can you please help me now? \$\endgroup\$
    – Karthik
    Dec 12, 2017 at 16:11
  • \$\begingroup\$ You are missing 0's in all terms in first equation. 8 becomes 80, etc. \$\endgroup\$ Dec 12, 2017 at 16:18
  • \$\begingroup\$ @StainlessSteelRat That doesn't change the outcomes of the equations. I checked it just now. \$\endgroup\$
    – Karthik
    Dec 12, 2017 at 16:22
  • \$\begingroup\$ Yeah I realized afterwards. \$\endgroup\$ Dec 12, 2017 at 17:59
Applying KVL on Mesh 1 :
80 = 10i1 + 20(i1–i2) + 30 (i1–i3)
80 = 10i1 + 20i1 - 20i2 + 30i1 - 30i3
80 = 60i1 – 20i2 – 30i3... ... (1)
Applying KVL on the Supermesh :
30 = 40i3 + 30(i3–i1) + 20(i2–i1)
30 = 40i3 + 30i3 – 30i1 + 20i2 - 20i1
30 = 70i3 – 50i1 + 20i2 ... ... (2)
Applying KCL at Node1 :
15i1 = i3 – i2
i3 = 15i1 + i2 ... ... (3)
Solving (1), (2) and (3) :
i1 = 0.583 A
i2 = -6.15 A
i3 = 2.6 A
Result :
v3 = 40 * i3
v3 = 104 V
    \$\begingroup\$ I have the same answers. \$\endgroup\$ Dec 12, 2017 at 18:45
