Consider a transformer primary driven by sinusoidal mains.
In my circuit I have an NTC thermistor in series with the primary which I short out after a few cycles to limit the inrush current at start-up.
This transformer is a very large torriod in my case 1800VA rated.
Now modelling this transformer as ideal (no losses) with a magnetising inductance \$L_m\$ in parallel with the primary we can work out the flux swing in the core.
$$v = N \cdot Ae \dfrac{\text{d}B}{\text{d}t} \Rightarrow \Delta B = \dfrac{1}{N \cdot Ae} \int_{- \frac{T}{2}} ^{\frac{T}{2}} V_{rms} \cdot \sqrt{2} \cdot \sin(2 \pi \cdot f \cdot t) \text{ d}t $$
$$\Delta B = \dfrac{V_{rms} \cdot \sqrt{2}}{N \cdot Ae \cdot \pi \cdot f}$$
Now because the transformer was allowed to saturate during start-up with current limited by the thermistor \$B_{max} \approx \dfrac{\Delta B}{2}\$ and \$B_{min} \approx - \dfrac{\Delta B}{2}\$.
Now we consider the transformer to have been running for several hours and we have a single negative half cycle drop-out (to 0V). Just prior to the drop-out flux density \$B\$ was at it maximum value ,and because the voltage has remained constant zero over the missing half cycle, has not changed. The next positive half cycle causes \$B\$ to increase and the transformer may saturate again. In my experience most commercial transformers do saturate.
Now let's change the scenario: Again we start the transformer but instead of having a half cycle drop-out we just turn it of precisely at the end of a positive half cycle. The flux density is at a maximum value. Does this stay the case forever as this simplified version of the maths suggests or is there a mechanism to reduce the flux density over time?
If so what is it and how would you estimate the flux density at some later time \$t\$?
