I have a three phase 380V system using 16A MCCB. Phase to Neutral is 220V. I want to install a single phase elevator that has the following specs: Voltage = 220V. Power = 3700Watt. If I calculate the current requirement with the following formula: I = P/V I get 16.81A (3700W/220V). I called the sales to reconfirm and they told me that the required current to operate the elevator is 25A. Now, since I am taking the power from a three phase system, will it provide enough power for the elevator? Can someone please teach me how to calculate the current conversion from 3P to 1P?
UPDATE #1: Thank you for the responses so far. However, if we put in the variables in rapidtables, it gives me just 7A (W=3700, V Type = Line to neutral, V=220, pf=0.8). Please note that my three phase source is 380V and I am using one of the three line to neutral to get 220V for the elevator.
