Why is parity_value equal to value of 1 ?
check_parity verilog source code
parity_error
module check_parity(clk, serial_in, received_data, data_is_valid, is_parity_stage, rx_error); // even parity checker
input clk, serial_in, data_is_valid, is_parity_stage;
input [7:0] received_data;
output reg rx_error = 0;
reg parity_value; // this is being computed from the received 8-bit data
reg parity_bit;  // this bit is received directly through UART
always @(posedge clk)
begin
    parity_value <= ^(received_data);
end
begin
    if (is_parity_stage)
        parity_bit <= serial_in;
end
begin
    if ((data_is_valid) && (parity_bit != parity_value))
        rx_error <= 1;
end
endmodule
I don't see any particular problem with your code as illustrated. I would assume that either:
  • received_data has a 0 time glitch to a non-zero value at the clock edge. If you know how to enable delta cycles on your simulator you can investigate that. You have events firing. Are any of them affecting received_data?
  • If your simulator behaves like Martin's and treats ^(exp) as !(exp) then your simulator is buggy.
If you run this code the first three columns should be equal
module top;
reg [3:0] a;
initial begin
   for (int i = 0; i < 16; i++) begin
      a = i;
      $display("%0d %0d %0d %0d", a[3] ^ a[2] ^ a[1] ^ a[0], ^a, ^(a), !a);
   end
end
endmodule
