I've put together an lm386 audio amplifier circuit as shown in the image below. The volume was good when hooked up to the 9V output on my trainers breadboard, but when I hooked it up to a 9V battery, I couldn't get any sound out of it. I measured an 8V voltage drop when between the positive and negative end of the circuit on the breadboard and a 2V voltage drop with the same circuit powered by a 9V battery.
This makes me wonder where all the power is going (if not through the audio amplifier) in the battery-connected circuit. I am guessing that there is greater current from the breadboard, which pushes electrons through the circuit, but would like a more definitive answer. credit: AfroTechMods
credit AfroTechMods
    \$\begingroup\$ current does not push electrons, voltage pushes electrons .... the movement of electrons is current \$\endgroup\$ – jsotola Dec 15 '17 at 8:30
  • \$\begingroup\$ bad 9V battery or bad breadboard? \$\endgroup\$ – jsotola Dec 15 '17 at 8:31
    \$\begingroup\$ I imagine the 9 V battery can't supply the current the load wants so the output voltage falls. \$\endgroup\$ – TonyM Dec 15 '17 at 8:56
  • \$\begingroup\$ You used to be able to buy a small speaker box with a built in LM386 amplifier. Those boxes had a single 9V battery for power. They worked well enough. So, this ought to work. It doesn't, though, so you've done something wrong. \$\endgroup\$ – JRE Dec 15 '17 at 9:24
  • \$\begingroup\$ I'll dig up a datasheet later and see where your circuit is different from the suggested circuit. \$\endgroup\$ – JRE Dec 15 '17 at 9:25
ESR of all batteries is inverse to mA rating so 9V battery is more than the DCR of a speaker.
I trust you understand how impedance divider reduces voltage.
What ESR did you expect?
There is a wide tolerance on this inverse relationship but is always true for the technology or chemistry.
|improve this answer|||||
turned out to be the battery. My multimeter was reading 9 volts, but when I swapped the Walgreens battery for a Duracell, it fixed all my problems :)
