as far as I know, when the items in case are not parallel
it would compose a priority routing network not the multiplexing network.
In other words, it should uses multiple 2-to-1 MUXs to represent priority in between the case items.
For example, below code has non-parallel case items 3'b11 and 3'b1??.
module non_parallel_but_full_case
input wire [2:0] s,
output reg y
always @*
//below case is not parallel but full case
casez (s)
3'b111: y = 1'b1;
3'b1??: y = 1'b0;
default: y = 1'b1;
endcase
endmodule
Therefore, I've expected the synthesized circuit may have MUXs not the ROM.
However, when I tested the code in the vivado and its RTL description shows ROM not the MUX.
Why the non-parallel case uses the ROM instead of the MUXs?
===================================================== Added question.
module decoder_2_4_if (
input wire [1:0] a,
input wire en,
output reg [3:0] y
always @*
if (en == 1'b0)
y = 4'b0000;
else if (a == 2'b00)
y = 4'b0001;
else if (a == 2'b01)
y = 4'b0010;
else if (a == 2'b10)
y = 4'b0100;
else
y = 4'b1000;
endmodule
The above code generates the multiple cascaded 2-to-1 MUXs.
However, the same logic implemented by the case statement uses the ROM.
module decoder_2_4_case (
input wire [1:0] a,
input wire en,
output reg [3:0] y
always @*
case ({en,a})
3'b000, 3'b001, 3'b010, 3'b011: y = 4'b000;
3'b100: y = 4'b0001;
3'b101: y = 4'b0010;
3'b110: y = 4'b0100;
3'b111: y = 4'b1000;
endcase
endmodule
In two examples, the result can be statically determined, and it would mean that two modules could be implemented by the ROM.
Then why it generates the different schematics?
