Today I was making a simple diagram in Visio Pro, when I needed to use a normally closed switch. Is there a way to place it? I haven't been able to find it!
Right click on the switch and you should be able to select switch state open or closed. If you want to label the contacts I think you need to edit the switch symbol or place text near the symbol.
  • \$\begingroup\$ Do I use Make Contact or SPST as a basic switch? I don't like the big circles on SPST but Make Contact doesn't have the Show closed circuit button. I'm really confused on which one you use for a normal switch. I'm using Visio 2016 \$\endgroup\$
    – user138346
    Commented Dec 19, 2017 at 13:38
  • \$\begingroup\$ I always used the SPST switch from Electrical Engineering › Switches and Relays category. \$\endgroup\$
    – mjh2007
    Commented Jan 9, 2018 at 19:30
Visio is NOT a schematic editor. As such I bet there are hundreds of electronic symbols it does not have. You have to draw your own.
I use ORCAD and even there I regularly have to draw my own symbols.
  • \$\begingroup\$ I agree, but sometimes you need to use what you have. \$\endgroup\$
    – mjh2007
    Commented Jan 9, 2018 at 19:33
  • \$\begingroup\$ ... or what everyone else in your organisation has. \$\endgroup\$
    – Transistor
    Commented Jan 15, 2018 at 6:59
  • \$\begingroup\$ And then there are dozens of decent dedicated online tools. \$\endgroup\$
    – MrGerber
