I'm trying to diy an electric lighter with a 3.7v lithium battery, an on\off switch, and a micro lipo usb charger.
Already connected the coil and everything works as expected.
The only problem I have is creating an enclosure for this thing. I want to try and make it the size of a USB stick or a key.
But I have no idea of what materials to use to protect the electronics from the heat. How far away do I need to mount the lithium battery?
Is there some coating or isolation I can add to dissipate the heat better ?
Am I over thinking it? (As an electric lighter is on for just a second or two and the heat generated is very short time wise)
Would making the enclosure metal help dissipate the heat? Or will the casing just heat up to an unpleasant temperature?
Help would be appreciated :-)
    \$\begingroup\$ I guess a lot of the heat will be radiation based, so you could get a sort of heat shield by a simple shining metal (you can try aluminium foil for a start). This will reflect most of the radiation and prevent it from heating your device. Make sure it doesn't short out anything. Your battery should stay below 40 °C for best performance. \$\endgroup\$ – Arsenal Dec 18 '17 at 8:42
    \$\begingroup\$ You're not overthinking it, the batteries are quite flammable. I'd suggest a thermoset plastic case inside a metal outer shield. \$\endgroup\$ – pjc50 Dec 18 '17 at 11:41
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
