first post, so I hope this isn't TOO stupid a question. I am planning on building this circuit:
https://github.com/trash80/Ym2149Synth/blob/master/Ym2149SynthSchematic-V29082016.pdf
which eventually outputs 3 audio signals from three pins on the YM2149 chip (see top right).
On the original I think these are just wired so that one is on the left of the stereo signal, and the other two on the right (? - correct me if I'm wrong!)
Ideally would like to complete the circuit with one 1/4" jack that outputs all three signals in mono, and then three separate jacks that output each pin separately.
Is there any issue with simply "tapping off" the signal from each pin post resistor to a separate output, before they go to the "all in" jack?
Would I need to add anything else?
thanks in advance for any help offered - I think other questions on here suggest it should be fine, but these mostly involve "Y splitter" cabling rather than actual circuit building.
